A/C Compressors need some pictures
Guest kjwheeler22
Guest kjwheeler22
Hello everybody I already did the Z conversion I have some pictures :-D hire is the web sight http://photos.yahoo.com/kjwheeler23 I would like to see some pictures of A/C compressors that some of you installed already so I can get some ideas when it comes time to put mine in I was thinking of using the standard chevy compressor with the V belt and try to add it on the pulley where the power steering belt suppose to be I will be using the original Z A/C condenser evaporator and accumulator that is already on the car and do you have some prices for the shop to make me some lines thanks this is my first post so go easy on me if I forget to add anything
I used Alan Grove Component's #113L "low profile" AC bracket. It sets the compressor close to the shock tower on my 75, but slightly shorter belt would fix that. I can email you photos if you need them, may take a few days.
Tim
Guest kjwheeler22
Mike kZ thanks for the picture I thought i seen your web sight before but i don’t remember seeing the picture must of skip over it :roll:
timh I would like to see your pictures the more ideas hire the better
did you have custom lines made? if so how much did it cost? right now i am just getting all the ideas together so i have some idea were i will start from. is the rest of your setup using the stock parts from the Z? thanks for the replies
Guest kjwheeler22
thanks for the pictures these will help me a lot. how good dose the factory system work like you have it and what pump did you use
  • 5 years later...
