mobythevan Posted May 14, 2003 Share Posted May 14, 2003 Searching around on the web for info and thought maybe you guys could help. I thought it would be helpful for pick and pull trips to put together a list of cars and the turbos that came on them, compressor trims and turbine ratios. Maybe you guys already have links to this info, that would be great. 81-83 280zx used garrett T3 with .60 a/r compressor and .63 a/r turbine (is that correct?) What about dodge turbo 2.2L lasers and daytonas Looks like 80's turbo fords may have used the same turbo as 280zx What other cars used the same T3 as the 280zx? Quote Link to comment Share on other sites More sharing options...
mobythevan Posted May 14, 2003 Author Share Posted May 14, 2003 Here is some ford info I found, all these used T3 Exhaust Turbine Sizes: 83-84 GT Turbo .60 & .63 A/R 83-84 Capri RS Turbo .60 & .63 A/R 84-86 XR7 Cougars .60 & .63 A/R 84-85 SVO .60 & .63 A/R 85.5-86 SVOs .60 & .48 A/R 83-86 TC .60 & .63 A/R 87-88 TC IHI Turbos Early 85 XR4TI .60 & .63 A/R 85.5-89 XR4TI .60 & .48 A/R Quote Link to comment Share on other sites More sharing options...
Lockjaw Posted May 14, 2003 Share Posted May 14, 2003 I think you will find the ford compressor housing is dfferent the the ZX one. 300ZX's also came with a T3. Quote Link to comment Share on other sites More sharing options...
CU Zcar Posted May 15, 2003 Share Posted May 15, 2003 Saab 900/9000 Turbo's apparently came with T3's, I have no idea on the A/R's. As you pointed out there the Dodge 2.2L Turbo cars came with T3's as well AFAIK. Supposing you have a bad 280ZX turbocharger and a good "other" T3 with a different compressor housing, will the 280ZX housing bolt on the "other" cartridge? Or would the difference in the other turbo's housing matter? Quote Link to comment Share on other sites More sharing options...
