Guest Anonymous Posted May 14, 2003 Share Posted May 14, 2003 Hi, I was wondering if you can put a T4 turbo on a 280zxt. I have a 81zx turbo. I know that response time will be laggy at first but on high rpm it will haul. Nevertheless, will it be bolt on and do I have to modify any thing much? Thanks Quote Link to comment Share on other sites More sharing options...
Lockjaw Posted May 14, 2003 Share Posted May 14, 2003 No it will not bolt on unless it has one of those one off turbine housings that matches a T3. You can get a flange and have someone weld it on your manifold and then port it out to match. Why not get a stage V turbine wheel in a hybrid? It would be easier to do, and they flow some good numbers and have one fewer blade then a P trim. I have a manifold set up for a T4 that I have had for a while and would send you a pic if you would like. I don't think you will find the P trim that laggy if you run the .58 ar turbine housing. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 14, 2003 Share Posted May 14, 2003 I was afraid of that. Thanks Lockjaw! Quote Link to comment Share on other sites More sharing options...
