TIMING DISTRIBUTOR QUESTION
Well I finally got my lifter replaced and engine assembled. I am ready to drop it in. I put in my distributor with the rotor facing the number one piston, top dead center on the compression stroke..yada yada yada. My question is do I start with the number one plug wire on the post that is pointing toward the number one piston (same as the rotor ) and then work my way around clockwise 18436572? Someone please advise, I dont want to do this incorrectly. :oops:
CorZette
Guest greimann
When viewed from the top, the rotation of the rotor is clockwise, so you are correct, the wires go on in the firing order clockwise.
