Gdemirchy Posted May 22, 2003 Share Posted May 22, 2003 I am thinking of turbo charging my 72Z, but with blow trough four barrel cab. Has any one ever done that ? and how much boost a four barrel carb can handle ? thaks Andre Quote Link to comment Share on other sites More sharing options...
Guest JAMIE T Posted May 23, 2003 Share Posted May 23, 2003 Check with some of the carb shops like Barry Grant, Devinci, AED, etc... They can tell you the information you're looking for They can build you a carb specifically for blow through turbo/supercharging. I think the main thing is pressurizing the entire carb inside a box. Quote Link to comment Share on other sites More sharing options...
Lockjaw Posted May 23, 2003 Share Posted May 23, 2003 I think you need to have the fuel pressure set up so that it goes up in proportion to boost. Ie if you need 5 psi for a holley, then when you add one pound of boost, fuel pressure needs to be 6 psi. Personally, I would find another way, or do a draw thru. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted June 9, 2003 Share Posted June 9, 2003 If I'm not wrong, there was an article in Grassroots motorsports... in the vicinity of 8 months ago. The car was called Gumby-Z, it was a spray-can painted 240z with a turbo'd 4bbl. Will look and see if I still have it around. Quote Link to comment Share on other sites More sharing options...
Guest Zcarsmakemyheadhurt Posted June 10, 2003 Share Posted June 10, 2003 It has been done a few times I have played with a Holly on boost, I like the clifford 6=8 intake and size the carb to the turbo you are going to use. The Holly would need to be worked for boost, the floats need to be filled to avoid being crushed by boost, bowl extenders are needed and a few other tricks. The Plenum needed to put boost threw the intake and car goes for $67.20 I have it in stock. You also need a regulator that converts hi fuel pressure to low and references boost. Lots of tricks need to be done for A carb on boost but they do work well. If you need help on making the project happen, let me know. I have most of the parts in stock. Quote Link to comment Share on other sites More sharing options...
