madmanadam Posted May 24, 2003 Share Posted May 24, 2003 Help, I have th350 with a b&m megashifter, having problems getting set. I have either first or park but not both. Ihave been back and forth many time just cant get it, to wild. park is better then first but first is funner Cruise tomorrow show on monday just for fun! Please advise me lost on shifter Thnaks Adam Quote Link to comment Share on other sites More sharing options...
fl327 Posted May 24, 2003 Share Posted May 24, 2003 could be a bunch of things i can think of right now. im pretty sure that you have tranny fluid up to spec, right? pull the governer out and pop it back in, see if that does anything check the shifter cable and where it goe on the trans, may be loose, check the shifter cable and see that the little bracket is going where its supposed to be. make sure you havent overfilled the trans. im hoping for the best for you right now, this happened to me with a 700r4 and it was internal, first and reverse share the same clutch and it was shot. hope yours is one of the easy ones, youre the one who got me pumped to do a v8z many many years ago. Quote Link to comment Share on other sites More sharing options...
