need an odd thickness head gasket
look here
http://www.scegaskets.com/results_IE4.asp
Gasket Bore 4.060 Thickness .021" special order thickness.
Gasket Bore 4.060 Thickness .032"
Gasket Bore 4.060 Thickness .043"
Gasket Bore 4.060 Thickness .050"
Gasket Bore 4.060 Thickness .062"
Gasket Bore 4.060 Thickness .072" special order thickness.
Gasket Bore 4.060 Thickness .080"
Gasket Bore 4.060 Thickness .093" special order thickness.
Gasket Bore 4.155 Thickness .021" 400 Gasket has no steam between cylinders, Special Order Thickness.
Gasket Bore 4.155 Thickness .032" 400 Gasket has no steam between cylinders
Gasket Bore 4.155 Thickness .043" 400 Gasket has no steam between cylinders.
Gasket Bore 4.155 Thickness .050" 400 Gasket has no steam between cylinders.
Gasket Bore 4.155 Thickness .062" 400 Gasket has no steam between cylinders
Gasket Bore 4.155 Thickness .072" 400 Gasket has no steam between cylinders, Special Order Thickness.
Gasket Bore 4.155 Thickness .093" 400 Gasket has no steam between cylinders,Special Order Thickness.
CHEVROLET 265-400ci V8 SMALL BLOCK PRO COPPER Head Gaskets Gasket Bore 4.200 Thickness .021" 400 Gasket has no steam between cylinders,Special Order Thickness.
CHEVROLET 265-400ci V8 SMALL BLOCK PRO COPPER Head Gaskets Gasket Bore 4.200 Thickness .032" 400 Gasket has no steam between cylinders.
CHEVROLET 265-400ci V8 SMALL BLOCK PRO COPPER Head Gaskets Gasket Bore 4.200 Thickness .043" 400 Gasket has no steam between cylinders.
CHEVROLET 265-400ci V8 SMALL BLOCK PRO COPPER Head Gaskets Gasket Bore 4.200 Thickness .050" 400 Gasket has no steam between cylinders.
CHEVROLET 265-400ci V8 SMALL BLOCK PRO COPPER Head Gaskets Gasket Bore 4.200 Thickness .062" 400 Gasket has no steam between cylinders
CHEVROLET 265-400ci V8 SMALL BLOCK PRO COPPER Head Gaskets Gasket Bore 4.200 Thickness .072" 400 Gasket has no steam between cylinders, Special Order Thickness.
You are defintely retired grumpy...shooting rants of info for no reason.
This has got to be the most cluttered forum I have ever seen...even over the Corvette® forums.
But its all good.
