Guest zfan Posted May 28, 2003 Share Posted May 28, 2003 My 1971 240Z has developed a slite fuel leak around the return line base and the fuel tank itself. I pulled the tank and while looking inside the tank I noticed some minor corrosion beginning. Should I repair the tank or trash it? Is there a coating or liner that can be put/sprayed in the tank? Also if I decide to install a fuel cell, do I need a fire wall between the tank and battery as well as passenger compartment? If I can help it I would like to keep from getting the boot at the local 1/4 mile track. Mike Quote Link to comment Share on other sites More sharing options...
Mike kZ Posted May 28, 2003 Share Posted May 28, 2003 http://www.eastwoodcompany.com makes a gas tank sealing kit. http://www.eastwoodcompany.com/aspfiles/itemdy00.asp?UID=2003052813570986&T1=10165+Z&Dep_Key1= Quote Link to comment Share on other sites More sharing options...
SpeedRacer Posted May 28, 2003 Share Posted May 28, 2003 Pretty normal for an old Z. If you don't want to do it yourself see if you have one of these around http://www.gastankrenu.com Quote Link to comment Share on other sites More sharing options...
VRJoe Posted May 29, 2003 Share Posted May 29, 2003 You may want to check with a local radiator repair shop, they can usually repair and seal gas tanks. - Joe Quote Link to comment Share on other sites More sharing options...
Guest zfan Posted May 29, 2003 Share Posted May 29, 2003 Thanks Guys! I probably will attempt to repair or have it repaired at a shop. Mike Quote Link to comment Share on other sites More sharing options...
denny411 Posted May 29, 2003 Share Posted May 29, 2003 Napa sells Red Kote, It works well for sealing fuel tanks and only costs about 20.00 Quote Link to comment Share on other sites More sharing options...
Guest zfan Posted May 29, 2003 Share Posted May 29, 2003 Thankd Denny, I will check it out today. Mike Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 30, 2003 Share Posted May 30, 2003 Ya, zfan; Gas tanks have a protective metallic coating at the beginning. When this starts to go those rust particles will surely find ther way into the carburetor unless you have a good line filter. The solution depends on your concern (and I suspect you know the answer already). A heavy duty filter will do the job and leave the tank as is, or as mentioned you can use the goop to cover the rust. But if it's rusting then the whole inside should be sealed and that would be a real job with an automobile tank. This stuff was originally developed for motorcycle gas tanks. I wouldn't use this "Bandaid" unless you don't care that much. Radiator shops can fix leaks and "Boil out" the innards in their tank but then all the inner coating would be gone and the goop would be mandatory. And everywhere the the torch burns the protective coating is lost. Your questions about the battery and fuel cell seem strange, for if you are doing the 1/4 then their rules will have to be applied. Otherwise and personally, I would definitly fully enclose the battery in a leakproof wooden box. Quote Link to comment Share on other sites More sharing options...
Guest 240hybrid Posted May 31, 2003 Share Posted May 31, 2003 I would recommend the eastwood gas tank sealer kit recommended above. I used this on my 75 280 tank in about 3-4 hours to clean and seal then wait to cure, and am very pleased with the results. The kit comes with everything needed except for muriatic acid and the acetone. I guess they dont like shipping such liquids and can understand. One person can do the job, but I had my father help me when needed. Using proper gloves and face mask to protect against acid and fumes, you'll have a very well sealed tank that should hold up for another 25 years. I figure a repair shop will charge at least double the cost of doing it yourself, and then you know it was done right too. The sealer is about the consistency of 10w-30 motor oil, so it should get in that small leak you have and seal it. Quote Link to comment Share on other sites More sharing options...
