One side of TS not blinking
On my '78Z, for some reason, the right TS in fron stopped working. I pulled the connector apart to check it with the light and I don't get anything, although the rear light does go on, and doesn't blink. Could I have broken a wire inside the connector? I even tried to de-oxidize the pins in the connector, with no luck. Is there another test point on the wiring harness to check the TS circuits?
Thx.
  • 1 month later...
The bulbs were all good. As a last resort, I took the TS mechanism off & cleaned it. Somebody put gobs of grease on it, so it wouldn't lock on. I also cleaned the switch contacts, which were dirty & greasy. Works fine now, except I need to go back under the column cover and LIGHTLY gease the TS mechanism.
NOW, I hear a KLUNK with every tuirn of the wheel to the right. the TS pin must be hitting something. Aaargh. :?
