Guest gbvol54 Posted April 13, 2002 Share Posted April 13, 2002 In the past you've recommended a Comp Xtreme 262 cam for a lift limited stock Vortec head sbc 350 with 9.5 static CR, performer rpm intake and quadrajet carb. I was headed in that direction but have found a couple nicely priced complete kits with different cam options: (1) single pattern, 222 dur @ .050, .467 lift, lobe separation of 110. (2) dual pattern, 214/224 dur @ .050, 443/465 lift, lobe sep of 112. Will either of the above get me around 350 hp @ 5500 rpm while maintaining a decent idle? Quote Link to comment Share on other sites More sharing options...
grumpyvette Posted April 13, 2002 Share Posted April 13, 2002 both cams will get close to the same power range (350-360hp), IF.. your useing block hugger type shorty headers not the stock exhaust manifolds on that engine the cam # 2 (looks like a summit or melling grind) will get you to 350hp and idle much smoother that the other one but neither one will idle perfectly smooth. but cam #2 is the better choice. Quote Link to comment Share on other sites More sharing options...
Guest gbvol54 Posted April 13, 2002 Share Posted April 13, 2002 Thanks Grumpy. I'm glad I asked. I would have leaned toward number (1). I'll be using block hugger headers and 350 hp should suit my needs fine. Again, thanks for your help. Quote Link to comment Share on other sites More sharing options...
