Bohnzii Posted May 31, 2003 Share Posted May 31, 2003 I have an early 74 Z. In the JTR manual it says to install a 15K ohm resistor to the blue wire going to the tach. My question is: Does the 15K ohm resistor replace the existing resistor already in the blue wire or do I add the resistor and leave the old one there also? Thanks Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted June 1, 2003 Share Posted June 1, 2003 They/re just saying that to make sure you have (one) 15k resistor in place. If you use two in parallel you got 7.5k. and if you use two in series you got 30k. .....and a screwy instrument either way. Thats how it works Quote Link to comment Share on other sites More sharing options...
