Faulty Safety Bleed Valve?
ok ok , on my l20et the saftey bleed valve is set to 4 psi, the wastegate is set to 6psi. (stock) .
Now this is a intresting problem. On Half throttle the car actually pulls better than it would on WOT . if i go full throttle, it builds boost then it just sits there venting it. im not sure if its out the safety valve or blow off vavle.
i narrowed it down to not being the blow off vavle since it has a totaly diffrent sound to this sound its making.
would it possibly be the saftey beed valve?. or some other possibility. ive checked for Vacume leaks and others.
any insites please, this is anoying probem :(
p.s im new to all this : / lol
