Guest torynich Posted June 1, 2003 Share Posted June 1, 2003 I have a 74 260 that I have been experiencing a batery drain on. I tried the test mentioned in the post on volt reading...with ignition off and went through all of the fuses and the light never went out. So I started unpluging things one at a time in the engine compartment. When I unplug the 2-spade connector on the alternator, the light goes out. Does this tell me the alternator is bad? I also noticed that the light goes out if I unplug the box next to the alt on the fenderwell (I dont know what it is but the top of it says Fuse:3A), not the smaller connector but the larger connector into it. Does anyony have any ideas? Thanks... Tory Quote Link to comment Share on other sites More sharing options...
Guest Aaron Posted June 2, 2003 Share Posted June 2, 2003 On a ZX I have seen a bad voltage regulator drain a battery. That might be your problem. Quote Link to comment Share on other sites More sharing options...
