How much is a stock 350 worth?
Your going to need to give more info than that...
What year?
Stock heads?
How big of a cam?
4 bolt mains or 2 bolt mains?
Are you talking from air cleaner to oil pan or just the long block or short block?
Unless it's built up it wont be worth much. 350's are a dime a dozen :( , which sucks for you. Are you planning on using it in your conversion or just selling it?
If its just a 350 with 2 bolt mains it really isnt worth anything most likely...if its a 4 bolt main you might be able to sell the block? Thats what I did with my old engine that I was going to use for my conversion before I decided on the LT1. I sold the block(4 bolt mains) for $120. The rest of the engine is currently sitting out side in the back of an old pick up truck. :cry: Oh well :cry:
Guy
You might get enough to cover the cost of machining and rebuilding the block, but don't count on it. A running 350 is about as easy to find as anything. If you want to sell it, sell it off as-is and let someone build it the way they want it.
