Guest Simon Posted June 2, 2003 Share Posted June 2, 2003 I have a VG30DET and was thinking about changing the inlet manifold, to a single throttle body, where i am going to put a GRA blowthru carbie, i have seen a firiends pathpinder (2002 model i think) it has a inlet manifold i liked. would that fint on a VG30DET, are there any others or will i have to go custom? Cheers Simon Quote Link to comment Share on other sites More sharing options...
Guest Simon Posted June 4, 2003 Share Posted June 4, 2003 even pictures of VG30s in cars for some where i can start my research Quote Link to comment Share on other sites More sharing options...
Guest tx84ae Posted June 12, 2003 Share Posted June 12, 2003 I have a VG30DET and was thinking about changing the inlet manifold' date=' to a single throttle body, where i am going to put a GRA blowthru carbie, i have seen a firiends pathpinder (2002 model i think) it has a inlet manifold i liked. would that fint on a VG30DET, are there any others or will i have to go custom? Cheers Simon[/quote'] Isn't a VG30DET already a single throttle body? Do you mean you want to change a VG30DETT (twin throttle bodies) into a single throttle body?? Quote Link to comment Share on other sites More sharing options...
Guest Simon Posted June 12, 2003 Share Posted June 12, 2003 Isn't a VG30DET already a single throttle body? Do you mean you want to change a VG30DETT (twin throttle bodies) into a single throttle body?? A VG30DET is a twin throttle body engine (well th one i have in my driveway is) Quote Link to comment Share on other sites More sharing options...
Pdfflyer Posted December 7, 2003 Share Posted December 7, 2003 Simon, I'm reading your post on the use of a single throttle body for this engine. I'm experimenting with the use of a Z32power.com 90 mm Throttle body on the same engine, altho originally designed for the Z32 Z engine. I found reference to Z32power.com on another website. The inlet is slanted to the right to accept incoming cooled air from the intercooler. Give it a look on that website and advise what you think. PDF Quote Link to comment Share on other sites More sharing options...
