GM fan switches
Guest Perry
Guest Perry
Hi all,
I wired my taurus fan by using an adjustable fan switch with a temp bulb to switch the fan from low to high and a GM fan switch in the water neck of the 350 chevy to switch it all on. The GM switch is a one wire switch that I thought would go to ground when temp was reached, but instead it appears to close on a diode which will only allow current to flow FROM ground. in other words, it doesn't work. I'm sure the switch I got was not a thermistor, and am considering blowing the diode out with too much voltage across it to see if I get lucky and it fails closed.
Has anyone out there got an application that I can use to get the right switch? I want it to go to ground when the fan should come on, maybe around 190 or 200 degrees.
I did try a search to no avail.
thanks,
Perry
