early z car 5 lug rear stub axle
Guest scca
Guest scca
there is a "possibility" of a run of custom rear stub axles made 5 lug and would also be making a companion flange to use a ZX CV shaft
there are 3 people interested already and looking to see if anyone else may be interested as there wont be more than one or 2 pairs made over what is needed- (will not be a stocking item)
no need for cv adapters then or welding on old companion flanges-
set price of 2 shafts and 2 flanges estimated to be around $800
$550 -600 for the pair of shafts and $250-300 for the flanges
will this stub be any stronger than a 280z stub? if so, im interested depending on the time frame this "possible" run happens.
dominic
Guest scca
would be stronger as the material would be better quality and outer flange will be better with the 5 studs instead of drilling-
  • 3 weeks later...
  • 3 weeks later...
