Guest thepenguin99 Posted June 11, 2003 Share Posted June 11, 2003 Nathan vs 72 240z Round 1: My wheel is sitting out about 1" at the bottom and I finally figure out my spindle/strut tube is bent. Replace strut tube/spindle with one from an early 260z. Think most of my wheel alignment problems are solved but now it makes sense to buy new springs/struts. Round 2: After waiting about a month for my suspension from shox.com (illuminas + tokico springs + bushings) I am ready to tackle the front 2 wheels. I start with the 260z strut tube and notice once it is together that the spring is VERY loose. Installed complete strut assembly into car thinking this was normal. Round 3: Now its time for the passenger side. I get this strut out and disassemble it. Then I proceed to chase down the parts because I neglected to get a spring compressor this time. After assembling this strut I notice my spring is no where near as loose as the other side. The spring fits just slightly loose so I have to look at the other side again. Round 4: Take measurements from the bottom of the tube to the perch on both strut assemblies. Turns out the 260z perch is about a half inch lower than my 240z for some reason. I dont have have another parts car so its a KO and the 240z wins. =( Quote Link to comment Share on other sites More sharing options...
j260z Posted June 12, 2003 Share Posted June 12, 2003 when i was reading my haynes manual i noticed that the free lengths (i'm guessing this means the unsprung length of the spring ) for the front springs are LH - 14.1" and RH - 15.1" for the 240z. the free lengths for the 260z fronts were both 15.5". seeing as i have an early 260z i didn't pay much attention to it but that may be where you've run into trouble. i would think that if you picked up another 260z front spring you would solve your problem. BTW the rear springs are all the same lengths at 15.0". Quote Link to comment Share on other sites More sharing options...
