Guest Anonymous Posted June 12, 2003 Share Posted June 12, 2003 hey i recently put an 82' turbo engine into my '77 but the engine is running REALLY rich all the time in all cylinders. it was like this before i put it in so i don't think its anything i did. i've tested the AFM,, throttle posistion sensor and fuel pressure. if anyone else has had this problem a little help would be greatly appreciated. also do you guys transfer in that auxilery cooling fan that stays on after shut down. i did, but i was just wondering if its really neccesary. thanks. Quote Link to comment Share on other sites More sharing options...
Lockjaw Posted June 12, 2003 Share Posted June 12, 2003 Check to make sure the head temp sensor on the passenger side of the head is connected. If it is, and appears to be working, check the fuel pressure and make sure your FPR is not going bad. Quote Link to comment Share on other sites More sharing options...
Guest tx84ae Posted June 12, 2003 Share Posted June 12, 2003 hey i recently put an 82' turbo engine into my '77 but the engine is running REALLY rich all the time in all cylinders. it was like this before i put it in so i don't think its anything i did. i've tested the AFM,, throttle posistion sensor and fuel pressure. if anyone else has had this problem a little help would be greatly appreciated. also do you guys transfer in that auxilery cooling fan that stays on after shut down. i did, but i was just wondering if its really neccesary. thanks. Just up that boost and it'll take care of the richness. *JUST KIDDING* Quote Link to comment Share on other sites More sharing options...
