zgeezer Posted June 15, 2003 Share Posted June 15, 2003 Here's a supercharger that should fit nicely on your CSB and under your Z hood. http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=34202&item=2418739937 gw Quote Link to comment Share on other sites More sharing options...
zgeezer Posted June 15, 2003 Author Share Posted June 15, 2003 No, I'm not shilling for this EBAY seller. His kit appears to be the "Paul" version for a Camaro. The intake is verrrry low, to allow assembly to fit under the Camaro hood. It will use a remote themostat that appears to be included in the kit. The intake volute mounted a Japanese "Weber" (I think it is a large Mikuni) or a four barrel carb. The kit looks as if it mounts the 4 barrel. A more modern adaption would be to drill the manifold for injectors and a rail. The "Weber" volute is just about the same size as the TPI throttle block (I know it's not the MAF sensor, but the unit a speed density FI system would use to meter/measure/calculate air flow). This might be more of an old timer's street rod unit: still they are effective and still have sex appeal (The What 'n ell is zat factor). gw Quote Link to comment Share on other sites More sharing options...
