Guest Anonymous Posted June 17, 2003 Share Posted June 17, 2003 My Z's been in storage for about 3 yrs, and I finally have some time and money to fix her up. One thing that kept happening to me before I put her away was the car either would start, than immediately shut off, or would start, idle normally, but if I moved the car (ie., pushed it with my hands, or even opened/closed the door) the motor would die. My buddies father said I "might" have vapor lock. First off, is vapor lock even possible with a fuel injected motor? Second, if so, how common is it to Z's? btw. 78, 280Z, 5 spd, everything's pretty much original. Quote Link to comment Share on other sites More sharing options...
PhaTTy Posted June 21, 2003 Share Posted June 21, 2003 You said it would die if you pushed the car or closed the door... Sounds like you have a really bad connection somewhere... It is definetely not vapor lock... That hardly ever happens on a Z, and your engine would have to be running extremely hot for it to even be possible. Quote Link to comment Share on other sites More sharing options...
