Guest toyotasupra17 Posted June 19, 2003 Share Posted June 19, 2003 ok dont laugh whats a fusible link ......i dont know whats happening to my car but ill try and explain.......ok i just recently purchased my first car for 150 and it happens to be a 1978 280z ....i have only driven it like 5 times so far and everyonce in a while when i turn the key it makes a grinding sound...will happen 1-3 times before the car starts, now this doesnt happen eveytime i start the car only sometimes.....next problem some times the idle goes way below 1k like around 500 but that also onlt happens once in a while.....i was driving the other day and all of a sudden the rpms dropped way down and the car shut off so i tried to start and wouldnt start for 10 mins of trying to start i could smell fuel when i was trying to start it.....next problem lol my radio worked then one day it didnt it was working fine then all of a sudden it just didnt work i changed the fuse and still nothing....and my last problem when i was driving and i turned to the left i got alot of wheel shake but it only happend like 3 times then stopped.........now can someone please help me out and let me know whats going on with my car she has 130k on her shes a 5sp and the body is in decent condition also can stock 280z's take 5.0 mustangs? cause alot of you say these cars feel sluggish but i think its fast as hell imo it roast's the tires like no other lol but all the help is appreciated Quote Link to comment Share on other sites More sharing options...
JKDGabe Posted June 19, 2003 Share Posted June 19, 2003 #1 - go get a new/rebuilt starter. #2 - don't know, maybe the AFM? #3 - sounds kinda like a loose wire, have you tried smacking the dash? I've got something similar in my truck but it's the radio itself and I have to insert and then eject a tape to get sound back. #4 - front end work time... "Can a stock 280z take a 5.0?" I doubt it although alot depends on the driver. Quote Link to comment Share on other sites More sharing options...
280Zen Posted June 19, 2003 Share Posted June 19, 2003 Quote some times the idle goes way below 1k like around 500 but that also onlt happens once in a while.....i was driving the other day and all of a sudden the rpms dropped way down and the car shut off so i tried to start and wouldnt start for 10 mins of trying to start i could smell fuel when i was trying to start it Could be a fuel issue, when I got my Z it had been sitting quite a while, 2 years! The fuel lines were clogged with varnish, the fuel pump was not pushing enough fuel into the fuel rail which would cause the rpm drop and stall, after a few minutes I would be able to start the engine again. It did get worse till I pulled the gas tank, cleaned the tank, sending unit, fuel rail and replaced the injectors. Quote Link to comment Share on other sites More sharing options...
Guest Venture-Z Posted June 19, 2003 Share Posted June 19, 2003 When the Idle drops can you still rev the motor? If not pull the intake hose behind the AFM (air flow meter) and see if that fixes the problem. If so it's your AFM. I went through 3 of them. Finnaly just ripped out the whole FI system, and put in a Holley 390. Good luck. Quote Link to comment Share on other sites More sharing options...
