over heating problem!!!?!!!
i was wondering if the over heating problem on my 240z is a problem with many other 240z owners? is it because the fan on the fan clutch isn't too good for cooling? or could it be something else? thanks!
You may have a bunch of gunk in your radiator. You may have no fan shroud. You may need a new thermostat--does it work for sure?
A solution in my mind: radiator flush, thermostat, Redline Water Wetter.
If it still does not go away, pressure check the radiator for leaks.
Davy
