Mounting my motor and transmission
Guest goldraven
Guest goldraven
i am haveing a local auto shop mount my transmission and engine and they need as much information as possible on how it needs to be done. if i remember correctly the engines motor mounts need to be 4in farther back than the stock 280zx mounts are located. is that the only thing that i can tell them to help them mount the transmission and engine? if it matters any i have a 350sbc and a T56. just any info or tips that i can tell the guys would be great.
thanks
Guest BigWhyteDude
have you got a copy of the JTR book handy? You could mabe refer to it but it doesnt really aply to the zx's Just a thought
Guest goldraven
the JTR book does not apply to the ZXs and i know that, so if it doesn't apply why would i get it? any more helpful info please?
Guest greimann
The mounts have to be pretty much inline with the datsun mounts. The ZX can't do the JTR setback like the Z. There are several way of doing this, Ross C, 80LT1 and I have all done this a little different. Here is my take using the GM clamshell mounts and biscuit isolators:
RIGHT SIDE
LEFT SIDE
Yeah I used the MSA motor mount and tranny mount kit. I didnt use the tranny mount though. I had to fabricate that myself. The motor mounts basically just take the GM 3 bolt pattern and adapt it to the Datsun 2 bolt pattern and use the proper amount of spacing between the engine and the towers.
I have some pics on my site of the motor mounts and how they are attached to my SBC.
http://www.datsun-280zx-lt1.com/SpecialPartsandMounts.html
http://www.datsun-280zx-lt1.com/LT1andT56.html
Hope this helps!
Guy[/url]
