trans bolts question
Guest cap1106
Guest cap1106
hey i finished reading the jtr book for the second time and i am about ready to put my engine and trans in my z. i have a queston though, can you get to the top transmission bolts once the engine in. in the jtr book they show them putting the engine and trans in together. i was just wondering if i need to do a clutch job later, will i have to pull the engine. thanx guys,
chris
Guest Your Car is Slow
I doubt you could get to them unless you cut/drilled some holes into your trans tunnel from the inside of the car.
In my IROC, getting those 2 top bolts (9/14's ?) hooked up to bolt the tranny and engine together was a complete job in itself. I ended up having to use some very long extensions and a glob of grease in the sockets to hold the bolt in place. Eventually about 2 hours later i had the top ones screwed in, and in place. I would imagine it would be harder in the tight spots of a Z?
