Guest Anonymous Posted June 30, 2003 Share Posted June 30, 2003 ok i bought a 280zx that wasn't runign and the guy i bought it form said that all i needed was a feul pump and intake boots so i got the fuel pump and the intake boots off a 83 and a stater/starter coil so what else do i need to get it running oh ya nad it has been sitting there for like 3years do i need to get all new fluids before or after i get it running i reall don't know much about 280zx but i'm learning slowly plz help Quote Link to comment Share on other sites More sharing options...
Lockjaw Posted June 30, 2003 Share Posted June 30, 2003 I would drain the tank, and put some new fuel in there, and a bottle of STP fuel injector cleaner, in the black bottle. determine if you have spark before going to all that trouble. You may have to work on the fuel pump too, it could be all gummed up. What happens when you turn on the ignition, you should hear the fuel pump come on and pressurize the fuel rail. If it doesn't it is likely gummed up and needs to be cleaned out. Brake clean or carb cleaner should eventually clean it out. You may also have gummed up injectorstoo. Quote Link to comment Share on other sites More sharing options...
280Zen Posted June 30, 2003 Share Posted June 30, 2003 Been sitting for 3 years? Ok, When I got my Zx it had been sitting for almost 2 years, I ended up replacing the injectors, pulled the fuel rail and spent hours cleaning the varnish out. Dropped the fuel tank and cleaned it out, Pulled off the rubber hose from the fuel rail to the fuel lines and replaced them. Replaced the fuel pump. Oh and replaced the fuel filter twice after I got the car running. Over the counter fuel injector cleaners did nothing for me. Quote Link to comment Share on other sites More sharing options...
