how to check turbo dizzy?
How do I check and see if my turbo distributor is good or not? I'm stamped on a Z31 ECU swap. I got my ECU to work. (little lights are on) and self diagnosed the system and it's throwing me a Fuel pump control code, crank trigger code, and one unknown (4 red and 1 green???) so I check the connector from the ECU to the dizzy and I'm getting no 12V from any of the pins. I think there should be one 12V on the 4 pin connector right? Thanks
