Coolant routing
Guest torynich
Guest torynich
I am doing a swap from dual webers to triple webers. The duals are set up with a coolant line flowing through them and dumping back in to the housing under the thermostat. The triples are not set set up this way. The car I took the triples off of was set up with a small line connecting the housing under the thermostat to the inlet housing on the block. My question is do I need to set it up that way or can I deleat this by-pass or whatever it is?
Tory
