Need Help w/R200 swap
Guest Shiin
Guest Shiin
OK Here's the deal. I have all the parts for the R200 swap the mustache bar, rear tranverse link, front mount, and front link.
Here's the deal. I got it to go up, but the front mount is not going in right. It's about an 1-2 inches off the mounting holes in the front and it looks like the differential is sitting too far forward. Do you have to reverse the mustache bar to bolt it up. I don't get it and it's been making me frustrated.
Please help
also, after you make sure that the mustache bar is in all the way, dont tighten the two bolts on the back all the way in, the front mount never wants to just line up straight, and the rubber band on top of the diff helps the alignment get a little harder as well. i use a small flat head screwdriver to align it, thread in a bolt part way on one side, then the other side, then the two other bolts that hold the front x member to the frame should be lined up.
