Guest Anonymous Posted May 6, 2002 Share Posted May 6, 2002 grumpy this is kidna directed towards you since you are the expert here. i have a 350 and i want to be able to put about 400 hp/tq to the ground. i was just wondering what you would suggest to get me to these numbers! thanks! Quote Link to comment Share on other sites More sharing options...
grumpyvette Posted May 6, 2002 Share Posted May 6, 2002 getting 400hp to the pavements not hard its affording the parts!!! 400 to the pavement means about 480-500 hp at the flywheel. look here at combos #93 and #102 (BTW BUILDING A 383 will make getting to 500hp easier)look at combos #16,#17,#71 http://www.ryanscarpage.50megs.com/afr2.html the key to 500 hp in a 350 is great flowing heads, a roller cam of about 230-250 durration @.050 lift, and matching the other parts to your intended use and rpm range. or cheating a little and useing nitrous (much cheaper, but your only superman while the bottles full)or adding a supercharger,add an 871 supercharger to a well built 350 with a matching cam and a set of these heads will easily get you 500plus hp http://www.procylinderheads.com/cast_iron_main.htm prt# 223 2600 35 A (Iron Lightning Series) http://www.superchargerusa.com/chevy_bk_street.htm Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 7, 2002 Share Posted May 7, 2002 thanks grumpy! you are the man! i really appreciate your help here! Quote Link to comment Share on other sites More sharing options...
