Weiand Stealth Manifold question?
Guest zfan
Guest zfan
Has anyone run a stealth manifold on their small block chevy? Im currently running a victor jr. and feel like it takes too long to come alive not to mention torque loss. I have a Rpm Air gap dual plane but do not think I can fit it under my hood with 750 holley on top. Its 3 tenths taller than my Victor jr. The stealth would allow me another 4 to 6 tenths of an inch. I know that doesnt sound like much but every tenth count.
So if anyone is familiar with this dual plane I would appreciate your imput. I did meet one guy who likes it on his Z. Hey Grumpy, Any Ideas?
Thanks, Mike :confused:
I've got one and it works great on my fairly stock motor. Not sure how it'd be with a bigger cam and more flow, although Weiand (depending where you read the specs) claims its good for 6800-7000 rpm's. Personally I prefer weiands stuff to edelbrock, but thats sort of a personal protest against edelbrock's stuff. The only thing about the Weiand stuff is it appears the sand castings are a bit rougher than Edelbrock if polishing is a factor.
Regards,
Lone
Ps: I' sure with a 3" drop base it'll fit under the hood, but I run a 5" cleaner with a cowl.
several people around here prefer the weiand 300-36 dual plain intake to the edelbrock rpm , Ive found them to be about equal and dependent on the cam as to which will run better.yes they will increase low and mid-range torque over a victor style intake but they also give up a little hp over 5500 rpm.
Guest zfan
Im running a comp cams extreme energy xr288hr. hyd.roller 236/242..520/540 with 110 lobe sep. with 1.5 roller rockers. The one thing that stands out is it is approx. one half inch shorter than my rpm air gap. I can use all the hood clearance I can get! Plus what kind of bottem end gains could I see? Victor jr. is out of my cam specs,cam comes on at 2600 advertised but with victor intake car comes to life closer to 3300. :(
Mike
Guest Rick Johnson
I gained extra air filter height by modifying my "dropped air filter base" even farther. By cutting out the 1/2" rise on the filter base which contacts the carb and then drilling holes to clear the float adjust screws, I was able to drop the base an additional 1/2". I even used a knurled head bolt instead of the wing nut to eliminate a pointed contact with the hood.
You should check the clearance between the front choke housing and the air cleaner lid. I cut some of my choke housing away to insure air supply to the front two barrels. (I aimed for 1 1/2" of clearance.
Hope this helps you get a reasonable air cleaner in.
Rick
Hi Zfan. I do have a stealth manifold with a 3" drop base filter. I do like it. Torgue sarts a t a low 2500 to 2600 rpm on my stock zz motor. I also used a 1/4-20 nut instead of a wing nut to gain a little more room. I do know what you mean by getting a much room as you can.I but a wing nut on and dinged my hood the first time I closed it.
