Guest Perry Posted July 10, 2003 Share Posted July 10, 2003 I'm not currently working on my Z because my recently purchased daily driver blew a head gasket. It's a 93 camaro Z28. I'm putting it back together and would love headers since the stock manifolds look like a major restriction and they are NO FUN WHATSOEVER to remove/replace. Being the sort to put way too many hours into something to save a small amount of cash... plus I need the cash for the Z ... I'm thinking of trying a set of summit brand block huggers with the collector flange cut off and a 2.5 inch pipe welded onto the collector with the appropriate bends to clear all the "stuff" in the way. I have a set that are installed elsewhere and fairly easy to remove for some test fitting, But I figured someone here could answer the initial questions below before I put some hours into getting the installed set off to try out. will the plugs hit the headers? do I have to move the knock sensor? are the ports reasonably ligned up? does the round tube header block part of the port? By the way a set of headers for this car are $300 used if not coated or a particularly good brand... which is why I'm willing to massage a set of $80 headers onto it. and the factory exhaust manifold is essentially a "log" type with approximately one exhaust port worth of cross section all the way to the y pipe, I think this may be an intentional restriction so the Vette could outrun the Camaro for that year. Being the "think out of the box-parts swappers" we are...Someone on this forum has tried this I'm sure.... Perry Quote Link to comment Share on other sites More sharing options...
Tim240z Posted July 10, 2003 Share Posted July 10, 2003 They will fit, but are far from ideal.. BTW, I have a set of those summit headers...never installed. Tim Quote Link to comment Share on other sites More sharing options...
