Lt1 Crankshaft question
Guest heinera
You can use an lt1 crank in an 87+ v8 block. But because of the older 2 piece seal blocks having a smaller opening, it won't fit in an older block (pre 87, or something near that ).
If you are worried about the balance, then use the lt1 pistons, and rods. They will fit in the block fine.
This is info I got from David Vizards book on budget small blocks. But is from my memory, so might be mixed up.
Adam
