Wiring diagram HELP!!!
Grog
Does anyone have a wiring diagram for the combination turn signal, wipers/head light switch assembly for a 1990 Mitsubishi Eclipse? The reason I need the help is that I am re-wiring my Z (from scratch) and I am using the Mitsubishi combination switch in favor of the stock Datsun one :idea: . So, I need to know exactly where the wires on this switch go to so that I can hook up everything properly.
ANY help is deeply appreciated! :D
Grog
The stock Datsun TS switch is just a SPDT switch, so you just need to look at what you got, and figure out how to configure it as SPDT, if it isn't there already. The headlight dimmer is just a push on-push of SPST pushbutton type.
At least it is on my '78 280Z...
I haven't taken apart the headlight/wiper switch, so you ogot me on that one. :(
Thanks for the reply guys, but that didn't help. I am aware that the stock Datsun is a SPDT switch, however the Eclipse unit is not. It incorporates an integral electronic wiper delay mechanism within the combo switch housing. So, the wires that come out of it are alien as far as I am concerned.
I have checked the public libraries with no luck (in BOTH counties). Rather than spend $25 dollars on a Chilton manual just for one diagram, and I don't own an Eclipse, i figured someone had the resource and would help me out.
