jmead Posted July 15, 2003 Share Posted July 15, 2003 OK, I posted before about a problem I was having. Sometimes car would backfire off idle during acceleration. Would run ok after that, maybe a little lacking in power, but driveable. Got a suggestion about a bad AFM. Got a new (used) one....same thing. Another...same thing. I took it off the road to fix the leaky gas tank. Fixed the tank, but now the car won't start. I can crank and crank, sometimes it will start for a second, run real rough and then quit, most of the time it doesn't even get that far. But I tried something out of desperation. With the AFM connected to the ECU, but not to the intake...same thing....but when I disconnected the AFM all together (both from the intake and the computer), it started and ran! Now, I didn't run it very long (no filter), and I didn't try to drive it, but at least it started. Now, what does this mean? Bad wiring? Something with the ECU? Did FI this old even have a "limp mode"? So...any suggestions? I love this car, but I can't figure it out...I really cant stand to have it just sit in the garage. Thanks for any input Quote Link to comment Share on other sites More sharing options...
jmead Posted July 15, 2003 Author Share Posted July 15, 2003 ...anyone? Quote Link to comment Share on other sites More sharing options...
Drax240z Posted July 15, 2003 Share Posted July 15, 2003 I'm not really sure... but maybe you can list your car, engine and any mods and that will spark an idea. What did you do exactly with the fuel tank? Quote Link to comment Share on other sites More sharing options...
jmead Posted July 16, 2003 Author Share Posted July 16, 2003 Ok, I've got a 76 280z Basically stock, had a 60mm TB with same problems (replaced it with stocker), and a K&N cone filter. That is pretty much it (for now) Also, for the gas tank. I drained it, washed it, cleaned it with a rust eating acid (metal ready), washed it again, dried it with hair dryer for 2 days, coated the inside with US standard fuel tank slealer, and as I let that dry I gave the outside 2 coats of POR-15. Quote Link to comment Share on other sites More sharing options...
