Guest Pyrogen_007 Posted July 17, 2003 Share Posted July 17, 2003 Do I use the factory rear sump truck pan or the car pan with the center sump? I'll probly be using a manual trannsmission TKO 2 if that matters, I have a while, its just something I thought of, and couldn't find using the search function. Quote Link to comment Share on other sites More sharing options...
dot Posted July 18, 2003 Share Posted July 18, 2003 I used the center sump pan when I had mine. The truck pump may be a good too if it drops the motor lower. I had to notch the hood latch bracket to get the motor far enough back. I found that the “A†body (Dart and early “Cuda) bell housing worked best as the pivot fork is lower and interferes less with the floor. Use the Z hydraulics with an aluminium spacer on the slave. It was faster than what I have now. Cheers …:::Glenn Quote Link to comment Share on other sites More sharing options...
