280Zen Posted July 22, 2003 Share Posted July 22, 2003 Has anyone ever seen or know where I could pickup the cable connectors for the stock EFI harness. Im looking for the male connector that is on the stock ECU. Quote Link to comment Share on other sites More sharing options...
Mudge Posted July 22, 2003 Share Posted July 22, 2003 Did you actually break one off the ECU or is there corrosion of some kind? I swear I have seen similar females, but can't say I've seen males like that. Quote Link to comment Share on other sites More sharing options...
280Zen Posted July 22, 2003 Author Share Posted July 22, 2003 Nope nothing wrong with my ECU. What I was going to try to do was, Build a pigtail connector to go from the EFI wiring harness to my megasquirt. So rather than rewire my car to use the megasquirt I would plug into the stock wiring and the megasquirt. If things went wrong or had a problem with the megasquirt I could unplug the pigtail harness and plug the stock harness back into the ECU. This would also allow me to tap off the stock harness for the couple of sensors that the Megasquirt doesn't handle, like the Thermotime switch and coldstart. (im running a 83 NA that has those sensors right now). Quote Link to comment Share on other sites More sharing options...
