Datsun660z Posted May 9, 2002 Share Posted May 9, 2002 It is the exact same swap I am not using the internaly balanced crank I do how ever have the smaller SFI damper and I am using the Large 168 tooth Flex plate with the Delco hitork starter from a 96 chevy 1/2 ton pickup that had the 5.7 liter engine (it is starter number 3 in the JTR manuel) my car is a 1976 280 = 660z Originally posted by Georgia Flash 75V8:Datsun 660, When you say that the 400 will fit fine in the JTR position are you using the 400 external damper or are you using the 350 set up that Grumpy suggested? The reason I ask is this, I may have a chance to buy a 71 Impala with the 400ci in the next couple of days and was wondering how much more work is invlolved in putting it in the Z rather than the 350. By the way I have a 280Z. Quote Link to comment Share on other sites More sharing options...
Georgia Flash Posted May 9, 2002 Share Posted May 9, 2002 Datsun 660, When you say that the 400 will fit fine in the JTR position are you using the 400 external damper or are you using the 350 set up that Grumpy suggested? The reason I ask is this, I may have a chance to buy a 71 Impala with the 400ci in the next couple of days and was wondering how much more work is invlolved in putting it in the Z rather than the 350. By the way I have a 280Z. Quote Link to comment Share on other sites More sharing options...
Georgia Flash Posted May 9, 2002 Share Posted May 9, 2002 Thanks 660, I may be heading in the 400ci direction. Say those "400" fender badges off of that Impala would look real nice on the side of my Z Quote Link to comment Share on other sites More sharing options...
Datsun660z Posted May 10, 2002 Share Posted May 10, 2002 They would look COOL, I am going to have 660z emblembs made that looks like the 260z emblembs Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 16, 2002 Share Posted May 16, 2002 Just a idea, but Scat also make a 4.00" stroke crank for the 400 block that will give you 427.64cid with a stock bore, 433.89 cid with a .030" overbore. Food for thought. Quote Link to comment Share on other sites More sharing options...
QWKDTSN Posted May 16, 2002 Share Posted May 16, 2002 *nod* I think that's the setup my friend kurt had in his fastest street car in SD trans am... a 434 small block. Quote Link to comment Share on other sites More sharing options...
