Guest butlersZ Posted July 24, 2003 Share Posted July 24, 2003 HI, I have an F54 block, turbo manifold, and two different inake manifolds. Also have an original '78 BLack Pearl edition Z and was considering making it a turbo. One intake I have is webbed and the other is not. Is there any flow difference between them? Also, would the turbo setup work with the '78 electronics? considering that I go with bigger injectors and a 240SX TB. I have no "turbo" head, but the head on the car is an N47 and I also have a P79, which would be the best combination and is it possible? Quote Link to comment Share on other sites More sharing options...
Len Posted July 25, 2003 Share Posted July 25, 2003 you could possibly do it except. With those hi compression heads, pistons; you won't be able to use much boost. Also your AFM is smaller than a zxt. I really think you would have much less problems if you could find the EFI off a 280zxt. That way it would be all there and just have to do minor tweaking. Better yet get the whole engine while your at it Quote Link to comment Share on other sites More sharing options...
