Corzette Posted July 25, 2003 Share Posted July 25, 2003 I have the AFR190 heads and intake. What I have noticed is that I MUST run a 1 inch spacer to get the carb to fit without hitting the PCV hose coming out of the intake. Is it OK to run filter on both Valve covers and let it vent naturally without worrying about internal pressure build up? I would then have to run my vaccuum for the brake line straight off my carb instead. Is that OK and has anyone had to do that? First time I have seen an intake like this. Any advice? Quote Link to comment Share on other sites More sharing options...
Mike kZ Posted July 25, 2003 Share Posted July 25, 2003 Will the carb still fit under the hood with the spacer? If so leave it, spacers usually give more HP. Also it is better to run one valve cover filter, with a PVC on the other. You'll get less of an oil mess that way. Quote Link to comment Share on other sites More sharing options...
Corzette Posted July 25, 2003 Author Share Posted July 25, 2003 Thanks Mike. I just wanted to make sure I didnt lose any HP by using it. Yeah I can still close the hood. Thanks.. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted July 26, 2003 Share Posted July 26, 2003 DELETE Quote Link to comment Share on other sites More sharing options...
Corzette Posted July 27, 2003 Author Share Posted July 27, 2003 Yep... Quote Link to comment Share on other sites More sharing options...
