to FastFrog
Guest Fast Frog
Owen:
As I remember, from 5 yrs ago (Geez getting old sucks!), my mini-ram didn't come with a hose neck. I think I bought the standard length GM type neck from JEGS with a bunch of other small accessories. Anyway, it's only 2"+ long. My top radiator hose is a standard GM rubber hose purchased from NAPA auto parts. I had to get a special bend configuration so I could get it from the radiator to the hose neck without interfering with my supercharger bracket and supercharger belt. My bottom hose a standard wire filled GM rubber hose and I'm using 5/8" rubber hosing from the coolant ports in front of the mini-ram to the heater sys.
However, at car shows, I've seen similiar configurations using steel braided hosing. As you know, the distance from the radiator to the block on a ZV8 is not that much diff from a stock GM V8 setup.
Hope this helps!
Rick
[This message has been edited by Fast Frog (edited August 10, 2000).]
