ccw wheel
Guest storm280z
Guest storm280z
i thinking about having so ccw wheels made 18x11 18x9 what kind of offset do i need an backspacing. an am i going to run into any axal problems :?:
Guest storm280z
:?: why 8'' coilovers. i cut like 4-6 in out of my fenders when i instilled my flare, so i could fit big rims. but i didnt know if the axels will hold or if it will need to do some kind iof mods
You should only need 4.5" backspacing if you do not have coil-overs. If this turns out to be too tight (for some odd reason), you can use some very thin spacers (1/4") to set the wheel out just a bit. Just some thoughts. If you are extremely curious, do a search in this forum to find out what backspacing you can use.
Davy
Guest storm280z
ok nevermind it worked this time. how do i get a hold of this guy or find out how he is. an by chance do you know his rim size
