Jwink25 Posted August 2, 2003 Share Posted August 2, 2003 I have several different ones laying around. I don't need 3 pulleys and was wondering what would happen if I removed the 3rd one? There are a couple of bolts that go through the damper and hold it on. By removing the 3rd pulley would I be risking the integrity of the unit? Do I need to replace the two bolts with shorter ones? Do they help hold on the 2nd pulley on or are they there only to hold the 3rd one on? I want to shave some rotating weight and help make the engine look cleaning. Thanks! Jason Quote Link to comment Share on other sites More sharing options...
evildky Posted August 3, 2003 Share Posted August 3, 2003 the third pulley was likely for an add on A/C system, that said you can remove it without and problems, I am thinking the bolts are needed to retain the other 2 pulley's I could be wron, just pull the one off and see if the others appear to need the bolts, learn by doing Quote Link to comment Share on other sites More sharing options...
Jwink25 Posted August 3, 2003 Author Share Posted August 3, 2003 I did take the bolts out and removed the 3rd pulley. The other 2 are stuck together. I was just wanting to make sure they would stay together. I guess I could put in a couple of shorter bolts and hopefuly not have to worry about it. Better safe than sorry. Thanks, Jason Quote Link to comment Share on other sites More sharing options...
