Guest scottjuly79 Posted August 4, 2003 Share Posted August 4, 2003 my car- 74 260Z, Toyota 4 piston caliper/300zx rotor up front, 79 280zx disk out back, 15/16 M.C., stock brake booster. At low speed I have an extremely sensitive brake pedal, the brakes feel way overboosted. I am on my second brake-booster and have tried everything else I can think of to solve this problem. I AM STUMPED!!! Any help would be greatly appreciated! Quote Link to comment Share on other sites More sharing options...
240hoke Posted August 5, 2003 Share Posted August 5, 2003 humm......maybe pushrod adjustment? Quote Link to comment Share on other sites More sharing options...
Drax240z Posted August 5, 2003 Share Posted August 5, 2003 thats what I was thinking too... if the pushrod is too far out you might be dragging the brakes when driving, and it wouldn't take much additional pedal pressure to really lock them up. I wish I had the same problem to be honest. Quote Link to comment Share on other sites More sharing options...
blueovalz Posted August 5, 2003 Share Posted August 5, 2003 Additionally, the booster valving may be applying a small vacuum signal to the diaphram (brakes) due to the pushrod being set too far into the booster. Quote Link to comment Share on other sites More sharing options...
Guest the_dj Posted August 6, 2003 Share Posted August 6, 2003 Same situation here. I gave up after replacing the booster, master cylinder, lines, proportioning valve, calipers, adjusting the pedal and bleeding the master cylinder and lines about a dozen times. Quote Link to comment Share on other sites More sharing options...
blueovalz Posted August 7, 2003 Share Posted August 7, 2003 I guess as a last resort you could remove the vacuum line from the booster to add some effort to your brake system. Quote Link to comment Share on other sites More sharing options...
