nightlightsnyny Posted August 6, 2003 Share Posted August 6, 2003 Hi, I have a tock 1978 280z. I have a chance to purchae ome 15x7 centerline wheels. What is the lowest profile tire I can fit? 225/50/15? 205/6015? Thanks Quote Link to comment Share on other sites More sharing options...
Guest zfan Posted August 6, 2003 Share Posted August 6, 2003 Probably 195/60-15. Mike Quote Link to comment Share on other sites More sharing options...
deMideon Posted August 6, 2003 Share Posted August 6, 2003 Well I have 16X7 and am running 245/50/16. The best way to determine it is to look at the tire manufacturer's recommended rim widths. This will get you the widest tire (if that's what you want!), without having sidewall problems. Quote Link to comment Share on other sites More sharing options...
Savage42 Posted August 6, 2003 Share Posted August 6, 2003 Hi' date=' I have a tock 1978 280z. I have a chance to purchae ome 15x7 centerline wheels. What is the lowest profile tire I can fit? 225/50/15? 205/6015? Thanks[/quote'] Depends on how much sidewall bow you want. With a 205, the sidewall will be straight up and down with the edge of the wheel. A 225 will give you a bit of bulge, but looks good on a Z. Depends on preference, I guess. Quote Link to comment Share on other sites More sharing options...
Guest ZmeFly Posted August 6, 2003 Share Posted August 6, 2003 and on the 15x7's im running 205 55 15's and they look just right. you could go with a 225 50 15 as well. you could possibly squeeze a 195 50 15 but i would and couldnt see why it wouldnt look right or good and with that small of a tire well you know Quote Link to comment Share on other sites More sharing options...
Jersey Posted August 7, 2003 Share Posted August 7, 2003 I'm running American Eagle 028 15x7's with 215/50/15 Dunlop SP5000's, Eibach springs with KYB struts. Sits nice and clears everything including the front air dam. Car dropped about 1 1/2" with springs. The Dunlops measure only 22 1/2" tall and with the T5, it makes the first two gears too quick in my opinion. Good luck. Quote Link to comment Share on other sites More sharing options...
