3 liter build intrference?
rags
Hi guys,
When assembling a stroker motor, is there interference between the con rod and cylinder wall on numbers 3 and 4? I have contact only on those two cylinders. Why? I'm using 9mm rods, ARP bolts and a 87mm bore. Thanks!
Joe
I beleive it is becayuse most strokers are using a 89mm bore. Talk to NOrm, the 12 sec dual SU dude. he has a stroker crank in a stock, non bored block. you may have to notch the bottoms of the bores to get it to clear, which should not be a big deal. hope this helps
McAdam
