235/60/15 drag radials what size rim
I will be in Reno for hot August nights this weekend, and Summit is there also. So I want to pick up some drag radial 235/60/15 but I need to find out what rims to buy.. 15x8 with a 5 or 4" back spacing? I do not have coil over but I have seen them on z-cars before without them.
Mike
Mike,
I've got coil over's on my '72. With a 15x8 wheel with 5" BS and 235/60-15 BFG DR's, I have about 1/2" between the tire
side wall and the threaded sleeve(coil over). The section width is 10" for the 235/60-15 BFG DR's when mounted on 8" wheels.
Without the coil over's, maybe use a 5" BS and then a thin spacer if you have clearance problems with the spring perch?
Good luck!
:cheers:
Don
