Guest dero Posted August 9, 2003 Share Posted August 9, 2003 ok so i beleave i have a stage 2 cam from crane cams, on the cam its marked C2, it came with the engine when i got it but i need to know the specs to what i should adjust valves to, currently i have intake at .012 and exhuast at .014, i dont think the motor is making enough vaccum to get my SU carbs working how they should, i tried setting the valves to stock settings at first but then it made barely any vaccum at all, the engine used to run on triple webbers but now im just trying to get it to idle on the su;s, so far since i adjusted the valves to .012/.014 it roared for about 3 seconds the died, pretty much whenever the starter is turned off the motor wants to turn off any help would be appreciated thanks. Quote Link to comment Share on other sites More sharing options...
evildky Posted August 10, 2003 Share Posted August 10, 2003 what oil are you running on your su's ? a thinner oil will let then move more freely, your's might be kinda stiff and a shot of wd 40 and moving them a bit might help as well, also be sure your fuel lines at the bottom of the fuel bowls flows well, I've found the sediment will clog the bottom not letting gas out so it'll barely run, hope some of this helps Quote Link to comment Share on other sites More sharing options...
