Anyone used 3M Underseal?
Guest thtdmbd8
Guest thtdmbd8
I am getting ready to undercoat my car and was wondering if anyone had used 3M Underseal. If so, can it be sprayed over POR15 of is it better on the metal itself? I am stripping the car completely and I want it to be quiet and solid, so any suggestions will be greatly appreciated.
I've done exactly what you're decribing. I used POR-15, let it cure for about a week, scuffed it with fine wet/dry sandpaper and applied 3 coats of 3M Rubberized Undercoating. The car is still on the rotisserie so it hasn't been road tested. However, it seems to have adhered well to the POR-15 and I am very pleased with the results.
I don't think that the Tie Coat product is necessary for undercoating if you make sure you scuff the POR and give the undercoat a good surface to adhere to.
  • 3 months later...
I've done exactly what you're decribing. I used POR-15' date=' let it cure for about a week, scuffed it with fine wet/dry sandpaper and applied 3 coats of 3M Rubberized Undercoating. The car is [i']still[/i] on the rotisserie so it hasn't been road tested. However, it seems to have adhered well to the POR-15 and I am very pleased with the results.
do you have pictures of this? :)
Guest bluex_v1
just a head's up: textured bedliner on the underside may be a pain to keep clean...all those fingers holding onto road grime. You can order it (Durabak for example) without the tire particulate if you're concerned about that posibility. I do love the stuff though and have it on the complete interior of two of my vehicles.
