Air cleaner threads stripped on my 650 DP, can I go to 5/16?
Guest cbrunberg
Hey Heavy,
If you use a wing nut to mount your cleaner or a rod couple you can JB Weld a stud in there.
Or you can JB Weld then redrill and tap.
Carl
Hey Heavy' date='
[/quote']
Great idea on JB welding the stud in the carb, Carl.
Just make sure that it is the CORRECT length before doing so, Brett, or you'll be peeved once it is set.
Davy
JB weld is my best friend...
It is 1000x cooler than my previous friend Duct Tape...
Just make sure that you dont allow any of that JB weld to get somewhere you dont want it. (I dont think you would really want JB weld in your intake manifold... )
good luck,
Joe
Guest Anonymous
after that lil race with len, my car has been backfiring ever since. not sure if i sucked up some more debri from the low fuel or if my exhaust has a hole. it backfires only during shifting when i release the gas and push on the clutch pedal...any ideas?
phuc
